anybody know how to get a msd tach wire to the factory tach?
Old Dec 23, 2001 | 05:07 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
I don't have an MSD but its a holley (clone). Someone cut the factory wiring and I can't seem to find any wire around the dist area that would go to the tach. The book says it's white. I want to try to hook my tach wire from the CD box to the factory tach. I tried to pull the instrument panel back to get at the wire that way but it seems to only pull back about 1/2 inch. I don't think the speedo cable is holding it but it might be.
Any suggestions?
thanks
Old Dec 24, 2001 | 12:20 PM
Changa2's Avatar
JC, if you can't find a White wire in the area of your distributor, try looking at the Bulk Head Connector. Should be located on the D/S Firewall near the Brake Booster.
On 85, 87 and 88's there is a White wire at the 'D6' pin, which is for the Tachometer. I don't know about 89's but this pin is in the 4th row down and 3rd from the left.
On my 87 I just spliced into that wire and ran it to the Tach pin on my MSD-6AL box.
I'm no expert but give it try.
Old Dec 24, 2001 | 04:20 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
It's on D6 in '92, as well, so I'd bet it's in the same location in '89.
Old Dec 24, 2001 | 05:33 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
d6 - thanks I will check there.. merry christmas
I get to give the 400 a christmas gift of some SS rockers (if nobody outbids me - please )
http://cgi.ebay.com/ebaymotors/aw-cg...item=599355406
Actually, now that I look at the C100 connector in the book, it says D6 -tach..
Helps to rtfm
Old Jan 24, 2002 | 08:45 AM
robert C's Avatar
i have a 90 rs and my tack is reading wrong it reads about dubble
than what it realy is i have monster tack in now but i want to fix
the other i unplug my tack{ i think } it stop working and hooked
it up to my msd 6al output and it read the same any ideas
Ikes 91Z
Dec 9, 2015 03:49 PM
overdriv
Aug 20, 2015 03:52 PM
midias
Aug 15, 2015 05:07 PM
stalkier
Aug 7, 2015 04:49 AM
