Need help wiring speedometer 91 Firebird
Old Mar 18, 2016 | 11:29 AM
brettr81's Avatar
Car: 91 Firebird
Ugh, previous owner did a hack job of an engine swap. Ecm is not connected, most connections for ECM cut or missing completely. That is fine, but I cannot find the wires from the VSS in that location. I can find them under the car and under the hood. Question is, which wire would I connect either the buffer box too, or if I get too pissed off with this connect a GPS speedo sending unit to?
Old Mar 22, 2016 | 08:48 AM
brettr81's Avatar
Car: 91 Firebird
Re: Need help wiring speedometer 91 Firebird
Bumpity bump bump. Any help?
Old Mar 27, 2016 | 06:57 PM
05gsxrk5's Avatar
this post may help you has a ton of info https://www.thirdgen.org/forums/elec...92-camaro.html
Old Mar 28, 2016 | 05:20 PM
brettr81's Avatar
Car: 91 Firebird
Saw that thread, of little help, but thanks though. I just ended up running new wires for the VSS. Pretty much it was easier than I was thinking but still a pain.Too many wires and connectors cut and just left hanging around.
87cam305
Oct 11, 2022 01:56 PM
83' 2.8camaro
Mar 3, 2016 12:02 PM
Bjerime01
Mar 1, 2016 07:01 PM
AdarianZ28/IROC
Feb 29, 2016 01:28 AM
rsrmoore
Feb 27, 2016 01:21 PM
