Won't Start
Old Apr 3, 2016 | 07:34 PM
stegal's Avatar
Car: 1990 RS, 2002 Chev Silverado
Won't Start
Some times my car will not start. The starter turns but does not engage the flywheel. I have put a new battery in. If I boost the car with a battery charger it will start. I have checked connections and they are good. When it won't start if I keep trying it will start sometimes but not others.
Old Apr 3, 2016 | 08:11 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Won't Start
Sounds like a starter solenoid or Bendix drive starting to fail. Same thing happened to me. Unless the starter gear gets thrown forward to engage the flywheel all you will hear is the starter motor turning. Maybe fixable without getting a new starter, depends on how much time and effort you want to spend
Have fun
Old Apr 3, 2016 | 09:01 PM
stegal's Avatar
Re: Won't Start
Old Apr 21, 2016 | 08:31 AM
stegal's Avatar
Re: Won't Start
Put new starter in and works fine.
Old Apr 21, 2016 | 10:25 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Won't Start
Have fun
The solenoid does two when the key is turned to "start":
  1. Kicks the starter drive out.
  2. When it kicks the drive out, this action completes the circuit that spins the starter.
If the motor is spinning, the solenoid is doing what it supposed to be doing. In the OP's case, it's the sprag n the drive that's faulty.
Veaceonee
Nov 9, 2019 10:52 AM
mjb198421
Apr 4, 2016 03:46 AM
dbd18
Apr 3, 2016 12:52 PM
xbmx89
South Central Region
Mar 29, 2016 02:14 PM
