0411PCM SBC Electrics Questions / Problems
Old Apr 23, 2016 | 02:34 AM
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Hi Guys,
My build is almost done and I have a few more hurdles to get over, and I was hoping maybe someone here could help me out with a few bits.
Firstly, I stripped the TPI motor harness and relays out completely and have just the power harness in the engine bay, there are no relays in the engine bay at all.
Does the 0411PCM still need relays for MAF?
Is the fuel pump relay in the cabin, the rear, or was it in the engine bay?
(if the latter is the case, how would i wire one in?)
Are there any relays the 0411 setup would need?
At the moment I'll be wiring a relay for the thermo fans and one for A/C
Will the 0411PCM with LS1 OS be able to use the 1997 Firebird LT1 gauges?
Will the fuel tank gauge work?
Do the LT1 Gauge lights for airbag,traction need to be wired if not used to keep the lights off, or can i leave them unconnected?
Are the coil packs powered by the PCM or does it take power from a relay or direct from battery?
Old Apr 24, 2016 | 10:03 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: 0411PCM SBC Electrics Questions / Problems
Originally Posted by evilstuie
Hi Guys,
The coil packs will be grounded by the ECM and receive power from a fuse or relay. Whatever fuel gauge you have will read the same as a thirdgen- 0-90 Ohm resistance. The fuel pump relay was beside the fan relay(s) and MAF relay near the C100 bulkhead connector on the drivers side. There was also a fuse for the fuel pump that was down by the battery attached to the fender rail. You will probably want to repost this in the LS1/LT1 engine board area. You also need to stop removing things and read the wiring diagrams. http://www.austinthirdgen.org/index.php?pid=45
You'll now need to go about adding the circuits back in or splicing the LT1 or LS1 harness into the thirdgen.
broke91firebird
Sep 2, 2019 10:02 AM
M3638
Apr 5, 2016 07:57 AM
L0tuS
Mar 30, 2016 03:21 PM
cobra20
Mar 18, 2016 03:33 PM
db057
Mar 14, 2016 08:53 PM
