LQ4 swap fuel pump
Old Mar 15, 2016 | 11:35 AM
cobra20's Avatar
LQ4 swap fuel pump
What fuel pump do you guys recommend that will work in the stock tank of a 1987 Iroc? Is there some factory GN fuel pump that will work or do I need to get an aftermarket pump? I'm trying to collect as many parts as I can before I go down and get my engine from where I moved from so I can try getting the swap done in the shortest amount of time possible
Old Mar 15, 2016 | 03:14 PM
Ikes 91Z's Avatar
Car: 1991 Camaro Z28
Engine: LS Conversion
Axle/Gears: Stock for now...
Re: LQ4 swap fuel pump
I see this is your first post. Welcome!
There are tons of build threads on here that touch on what is needed in terms of fuel pumps and lines. there are different options to go with based on if you are keeping the stock fuel tank or updating. In my build I used a corvette filter with a built in regulator, and built brand new fuel lines from the tank to the engine.
I am not sure if a stock 4th gen fuel pump fits on the sending unit of a stock 3rd gen, someone else can chime in and confirm/deny. I went with a walbro 255 for my pump.
I would also read through the LS swap stickies as they really lay a lot of the big modifications needed.
Old Mar 15, 2016 | 11:01 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Walbro 255 intank pump,corvette filter/regulator and run new braided fuel line front to back is the best way. You can use a 4thgen tank/pump assembly but requires more plumbing and wiring iirc.
Old Mar 15, 2016 | 11:36 PM
cobra20's Avatar
Well I'm hoping to use the stock fuel lines that are in the Iroc. I'm also planning to use the stock truck intake and accessories. So the stock truck fuel rails already have the regulator on them. My plan is to use the Holley engine mounts, transmission cross member and the Holley LS swap oil pan.
Old Mar 17, 2016 | 11:40 AM
cobra20's Avatar
Is the Walbro 255 a good fuel pump to use on the LQ4 swap?
Old Mar 17, 2016 | 01:27 PM
R13_Braz's Avatar
Car: 2014 Z28 #80
Walbro 255 is good for most swaps. But you can't just go off of that. Need to do research into what fuel flow you'll need to support whatever HP goal you have.
Old Mar 17, 2016 | 04:45 PM
cobra20's Avatar
Right now I'm thinking of just leaving it stock for now and build it up later on after it's up and running.
Old Mar 17, 2016 | 06:16 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Probably be wiser to upgrade now.
(A) Fuel system is already open
(B) Not being able to supply adequate fuel at correct pressure is going to jack with your ability to tune the engine.
Old Mar 17, 2016 | 06:35 PM
cobra20's Avatar
That's why I'm asking about the 255, what would you suggest if I was going to try for around 400hp eventually
Old Mar 18, 2016 | 03:33 PM
R13_Braz's Avatar
Car: 2014 Z28 #80
The 255 can comfortably handle that.
There are several calculators out there that can tell you how much flow you are going to need to handle whatever horsepower goal you have. Look on google for one. Some even tell you what injector size you'll need to comfortably run the HP you want.
Tremo
Mar 26, 2016 02:23 PM
AmpleUnicorn88
Feb 25, 2016 06:19 PM
AmpleUnicorn88
Brakes
Feb 22, 2016 07:44 AM
articwhiteZ
Aftermarket Product Review
Feb 21, 2016 02:43 AM
Bmurphy
Feb 19, 2016 05:30 PM
