Headlight issue
Old Apr 23, 2016 | 10:34 PM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
Headlight issue
I just bought a 91 firebird and the headlights are not functioning properly. They attempt to raise but are unable to lift all the way up. They come about halfway up. The lights are working fine. Is there an adjustment to the motor that will correct this?
Old Apr 26, 2016 | 01:05 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Headlight issue
The hard OEM gel bushings inside the gear within the motor are broken into just chunks. You need to repair the headlight motors using a headlight repair kit:
http://www.top-downsolutions.com/Bod...ght-repair-kit
Once you have repaired the motors using the Delrin bushings your problem will be solved.
Lon Salgren
Old Dec 13, 2016 | 08:19 PM
Evilokc's Avatar
Engine: tbi 305
Re: Headlight issue
I lubed up the tracks on the headlights and they work perfect.
Old Dec 13, 2016 | 09:02 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Headlight issue
Evilokc, I suggest that you get the delrin bushings in the link that Lon provided above. Its not a matter of if, but when, the stock bushings crumble and your headlights fail to rise again. Its an easy fix.
Old Dec 13, 2016 | 11:29 PM
Evilokc's Avatar
Engine: tbi 305
Re: Headlight issue
I'm sure they will fail but "fixing" them when they work great is like buying new tires when mine are fine because they will wear out eventually. when they crash and I know they will I will rebuild em but I lubed them in april and they are still working great. there are parts of my car that are broken Like the heat that get my immediate attention
Old Dec 13, 2016 | 11:49 PM
lonsal's Avatar
Re: Headlight issue
I see no problem in waiting to fix them until they begin to fail. I'd only caution when they do begin to act erratically don't wait too long. If you wait until they no longer will raise with a few flips of the headlight switch or by manually cranking the top ****, you have now turned a one-person job into a two-person job. Now someone else will have to turn on/off the headlight switch as you bang on the headlight bucket and shake it until it FINALLY decides to raise up suddenly. Again, no problem with waiting to do the repair. I'll be here with the kit when you decide you finally need it.
Lon Salgren
Top-Down Solutions
soul.justice
Exterior Parts Wanted
Aug 20, 2016 02:03 PM
Mark Walker
Apr 14, 2016 12:06 AM
94ElBanditoDeCa
Apr 13, 2016 11:12 PM
smokingss
Firebirds Wanted
Apr 12, 2016 09:57 AM
wgripp
Apr 8, 2016 10:35 PM
