Alternator Wiring Help Needed - 12S to CS130
Old Apr 25, 2016 | 11:38 PM
Citadel's Avatar
Car: 1983 Pontiac Firebird
Engine: 5.7L from 1996 Chevy 1500
Transmission: 700R4 from 1985 Pontiac Firebird
Hello All-
This is my first post so first of all, thanks to everybody for all the information on the forum! The short story is I removed a 12S and am installing a CS130. My problem is that there were three wires on the 12S- one to the battery, a brown wire to the idiot light, and a big red wire that ties into the starter and heater wiring. The CS130 came with a pigtail that has wires coming out of the F and L terminal. There is no S terminal wire. The brown wire will go to the L terminal wire, the F terminal wire would have went to the computer from the donor vehicle. I am not running the computer so I will terminate that wire. Now I have this big red wire that I think could go to the S terminal, but I don't have that provision on my pigtail. Would it be fine to just run it to the batt terminal on the alternator? Or should I just go find or order a new pigtail with the S terminal provision?
Old Apr 25, 2016 | 11:45 PM
Citadel's Avatar
Re: Alternator Wiring Help Needed - 12S to CS130
Other information that may be helpful: The car is an 83 firebird (originally a crossfire). I'm working on installing a 350 from a 96 chevy 1500 that I've switched over to carburetor. The alternator (and the rest of the accessories) have been donated from a 1992 chevy caprice. This is my trans am that I'm patching together from other projects and junkyard upgrades.
Old Apr 25, 2016 | 11:58 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Do not apply full battery voltage to the L terminal as it will burn out the regulator. Search for 12si to cs130 wiring and you will get all the info you need. There are a few posts about this conversion here in the electronics section. HTH!
Old Apr 26, 2016 | 12:39 AM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Axle/Gears: 3.07
This should help.
Attached Thumbnails Alternator Wiring Help Needed - 12S to CS130-cs144wiring01.jpg
Old Apr 27, 2016 | 12:19 AM
Citadel's Avatar
Thanks bigal55. I stopped by my local parts store and picked up the proper adapter and everything looks good. I'm slowly working towards cranking this engine for the first time.
Old Apr 28, 2016 | 10:51 AM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Axle/Gears: 3.07
Glad I could help!
Bluestreek
Apr 19, 2017 03:16 PM
wiskerchen019
Apr 16, 2016 05:38 PM
789roby789
Carburetors
29
Apr 9, 2016 08:09 AM
MyNasty91
Apr 5, 2016 08:39 PM
Falcon50
Mar 30, 2016 02:20 PM
