Steering column issues
Old Apr 30, 2016 | 10:46 AM
patrickz1985tgc's Avatar
Car: red 1985 z28 camaro
Engine: 5.7 edelbrock
Axle/Gears: 3:73
Well i bought an 85 camaro and the thing only cranks when my tilt steering wheel is all the way down. If it's up by any chance it'll crank but won't turn over. I'm a newbie to this stuff so I've been trying to do research but no luck. I believe it's some sort of wiring going on that i don't have a clue of.
Old Apr 30, 2016 | 12:10 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: Steering column issues
Could be broken wires from the ignition switch through the column. AustinThirdgen has the wiring diagrams you need to troubleshoot this problem. Study them and plan a logical step by step test to determine if you are getting power from the ignition switch to the starter solenoid and also ignition power from the switch. Could be power going to the ignition switch so check that first. HTH!
Old Apr 30, 2016 | 05:09 PM
Axle/Gears: 3:73
Yeah i will check that site out. Thanks
Old May 1, 2016 | 03:03 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
It's most likely an adjustment issue with the ignition switch that's located down at the bottom of the steering column.
I've had older (1960's) Comfortilt columns apart so I don't know if 1980's columns are different (I would think the principle of operation is similar).
When you turn the key, the key cylinder operates a rod thingy that travels down the column and operates the ignition switch. The rod mechanism "compensates" for the length difference when the wheel is tilted up/down. But the compensation only works correctly if the switch is properly adjusted.
Crawl under the dash, remove the hush panel and observe what's going on at the switch when you turn the key. You can loosen the switch and move it slightly so the the rod pushes/pulls a little more when the wheel is tilted down. I "think" you'd want to move the switch up towards the steering wheel slightly.
Check the switch operation in both full up and full down tilt positions before crawling out from underneath.
Old May 1, 2016 | 10:18 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
https://www.thirdgen.org/forums/elec...on-switch.html
sahlomonic
May 11, 2016 12:33 AM
91charlene
May 9, 2016 10:33 AM
tecboy
Interior Parts Wanted
Apr 5, 2016 01:12 AM
erik69&85
Apr 3, 2016 01:33 PM
87zz28
Apr 2, 2016 04:29 PM
