Won't Start, Won't Turn over
Old May 8, 2016 | 09:31 PM
CamaroKid97's Avatar
Car: 89 Camaro RS
Engine: 355 Swapped From 305
I have an 89 Camaro 5.0L w/ A/T
Well, took my car out for a spin and on the way back it randomly just killed. No weird noises just instant loss of power. Got it back home and tried to replace the ignition switch... didn't work. Tested a couple of places (Battery, Fuse box, etc.) for battery voltage and everything read what it should. The weird thing is, is that the interior lights work, the headlights work but no dash lights light up and the car wont even turn over.
If you guys have any ideas give me a shout, thanks much appreciated!!!
Old May 9, 2016 | 12:15 AM
Fabrik_8's Avatar
Car: 86 belinneta with 83 front end
Engine: 383
Transmission: M20 muncie
Axle/Gears: 2.73 (till I get some 3.73)
Re: Won't Start, Won't Turn over
Have you checked the connections at the starter? Check the wires around that erea to see if nothing butned up by the exhaust. Its happened to me before
Old May 10, 2016 | 01:40 PM
Car: 89 Camaro RS
Took a peek but their still good.
Old May 11, 2016 | 09:03 AM
Yup, sounds like one of the 2 fusible links at the starter, died.
Each link powers about half the car. I.e. it's highly likely that the one that shows up at the fuse block might still have power, but the one that powers the ign sw might not.
Replace them both. Just do it. Life is too short to spend futzing around over a $3 part. Or even, 2 $3 parts. http://www.summitracing.com/parts/rnb-85621
Old May 13, 2016 | 06:35 PM
sleprock's Avatar
Car: 1986 irocz
Engine: 383 with ds1 procharger
Axle/Gears: moser 9' 370's
check your nss by the shifter. jump the big purple wire with the big yellow wire at the switch connector. if your car starts change the nss. i had this issue.
santiclause
Apr 29, 2024 10:48 AM
ChevyKen
Convertibles
Jun 5, 2016 02:07 AM
santiclause
May 9, 2016 08:25 AM
Anomaly
Exterior Parts Wanted
May 7, 2016 12:04 AM
BG1959
Apr 29, 2016 09:04 AM
