What are the chances....
Car: 1987 IROC-Z / 1992 Corvette
Engine: 305 TPI / LT1
I accidently shorted out the ignition module in my 1987 IROC (305 TPI).
What are the chances that the pickup coil is toast as well?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Pickup Line
Once you have a good ICM in there disconnect the 4 terminal connector at the distributor.
If you then have spark replace the pickup coil.
Happy Racing !
If You Need To See Brake Lights To Know When To Apply Yours . . . . . . . . . GET OFF THE ROAD IMMEDIATELY!
Happy Racing !
Re: What are the chances....
Thx for the response - I ended up buying a new distributor. I couldn't get top magnetic "shell" the pickup coil sits in off to replace it - not even with a hammer.
Still having problems. I'm going to search & if I can't find anything useful I'll start a new post.
Thx again - I'll make a note of this in my book. Good to know.
[NC] 305 tpi LB9 for sale
86ZRESTO
May 21, 2018 08:33 AM
