headlights dim on right side
Old Dec 26, 2001 | 01:12 AM
Ride4ME's Avatar
I've tried new lights and I know it's not
a fuse b/c the left side works fine.
Someone help me!!!!
Old Dec 26, 2001 | 03:32 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Make sure the lights chassis ground is clean & tight. Bad grounds can do some very strange things...
Old Dec 26, 2001 | 04:18 PM
Winnipeg_Firebird's Avatar
I had the exact same problem, I looked at my headlight wiring and found that my ground had just about fallen off!
Good Luck!
Old Dec 27, 2001 | 01:27 AM
SgtSkip's Avatar
Like deadbird said, check your connections. They're the most likely suspect. Look for corrosion in your headlight plug, dirty contacts, etc. run a little sandpaper over them and then ad a little dielectric compound to help keep moisture out.
Old Dec 28, 2001 | 01:12 PM
Ride4ME's Avatar
Thanx, I just went to a junkyard
and got a replacement set of wires.
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
LittleFranks
Sep 17, 2015 12:22 PM
Fronzizzle
Aug 17, 2015 02:52 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
