Several things not working, fuse issue?
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
Hi gang
Just got a nasty code 42 resolved on my car. Now I am going to take her in for inspection and several things are not working:
Horn
Power adjusted review external mirror switch
Door lock switches
Power antenna
Everything is fine. I am sure this is just a fuse issue. Been searching but the wire diagrams are confusing. Thoughts please? Thanks!!
Horn
Door lock switches
Power antenna
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: Several things not working, fuse issue?
I would check the 20A(yellow) accy fuse and go from there. Good luck!
Engine: 5.7
Axle/Gears: Stock
