Stupid stupid stupid LED problem
Car: 1983 Pontiac Firebird
Engine: 400HP 350
So in light of being completely broke, I was able to scrounge up the money for some 194 LEDs for the sidemarkers on the bird. I have a weird problem! No flashing side markers with the headlights/parking lights off. Everything else still flashes, and the LEDs flash once the parking/headlights are on but not when off. Makes no sense other then I need to upgrade to an electronic flasher. I didnt think that side markers would cause a non flashy kind of issue. Member
Car: Red 1991 Firebird with digital dash
Engine: L03 V8 TBI
Transmission: 700 R4
Re: Stupid stupid stupid LED problem
Sorry tp hear you're broke. But I fear you'll have to get an LED flasher. I had the same problem even when I only replaced the turn signal bulbs in the dash.
Engine: 400HP 350
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Electronic flasher may/may not fix it & if you ever upgrade to LEDs in the front &/or rear.Youll back in the same boat.You can make them work with a relay too, but youll need one for each LED.
Engine: L03 V8 TBI
Sorry, I was just referring to my 91 FB. Yes, I once replaced all the bulbs in the analog dash with LEDs, keeping all the exterior incandescent bulbs and the turn signals wouldn't flash anymore. Had to switch back to bulbs in the dash for the turn signals.
One solution to your problem could be to use LED bulbs that can be put in in both directions. Some from superbrightleds dot com have that feature. Don't know if they are strong enough for turn signals though...
[WI] Complete stealthram
stealthram92z
May 5, 2016 06:58 AM
kg1922001
Apr 5, 2016 08:22 PM
