Interior led lights - Best power source?
Old Apr 11, 2016 | 04:08 PM
tecboy's Avatar
Engine: 350 - 305 801 Heads
Axle/Gears: Stock
Hey all,
simply want to run a small string of led lights under the dash to shine on the floor. In searching for a power source, i have to remember, I only want the lights to turn on when a door is open or if I turn them on with a switch.
I located an orange and white power source under the dash that seems to work when i tested it. If the door was open, it had power to the led, if it was closed, no power. I have since blown a fuse as I grounded it and bam lost the fuse. Is there a better option than using this source or am I on the right track?
tec
Old Apr 12, 2016 | 06:07 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Interior led lights - Best power source?
Sounds to me like you are on the right track.
Old Apr 12, 2016 | 07:48 AM
tecboy's Avatar
Axle/Gears: Stock
Thanks Dyno, now that I have blown a fuse, I cant seem to find it anywhere. Any ideas where the fuse is? I checked all the fuses in the fuse block. Is there another block I need to check? Thanks in advance
tec
Old Apr 12, 2016 | 05:35 PM
AmorgetRS's Avatar
Orange should have power all the time. It's the white ground that is completed when you open the doors. The orange wire is powered off of the CTSY fuse.
http://austinthirdgen.org/mkportal/m...ody_wiring.gif
Old Apr 16, 2016 | 02:22 AM
MyNasty91's Avatar
Car: 91 RS Camaro
Engine: 3.1 in the begining and now a 5.7
Transmission: 700r4 w/ 2500 stall
What I have done in the past to add additional LEDs to my interior is go to my local auto parts store and picked up a fuse panel. They are small and easy to hide. Normally down the same isle as fuses, bulbs, wires, etc. Also pick up a positive battery terminal that allows for another wire to be run. Run the positive wire thru the fire wall and to the panel. And from there just wire the lights accordingly. It doesn't add the strain to the factory wiring and blow fuses that way. And as far as turning on and off with the door, you can pick up door contact switches. I hope this helps you out, good luck.
Old Apr 16, 2016 | 02:23 PM
tecboy's Avatar
Axle/Gears: Stock
Thanks for all the suggestions. I used the white and orange wires as they were door light lighs anyway. I open either door and the leds come on blue. Nice effect. Now I realized I ned to wire a switch to turn the lights on when the doors are closed. Thanks again.
Tec
Old Apr 16, 2016 | 03:29 PM
BOTTLEDZ28's Avatar
Transmission: A4
Tec
You already have that override switch. Its built into the headlight switch. Just turn it until the dome light turns on. It should also turn on whatever else you tied into the circuit.
Old Apr 18, 2016 | 11:29 AM
tecboy's Avatar
Axle/Gears: Stock
Dugh! Never thought about that! Great suggestion. I will check it out later. Thanks bottled
-srs-
Mar 12, 2017 05:13 PM
czlowiekmucha
Jan 18, 2017 02:11 PM
propaintball96
Apr 12, 2016 01:30 PM
nuggie
Apr 10, 2016 10:01 PM
DARKmj16
Apr 5, 2016 01:12 AM
