No reverse lights wire in Manual 82' Z28 turned Automatic | WHAT DO?!
Old Jul 6, 2016 | 11:42 AM
82' Z28's Avatar
My car will also start in any gear which my friend believes is directly related.
This seems quite a problem as I believe I legally and for my own safety need reverse lights.
I discovered this when I went to tweak the neutral switch and upon inspection learned there was no cable connected to it nor can I find one in my shifter. Thoughts?
https://i.imgur.com/rD0fZb0.jpg
Old Jul 6, 2016 | 11:51 AM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: No reverse lights wire in Manual 82' Z28 turned Automatic | WHAT DO?!
I assume you did not do the swap yourself? The neutral safety switch was originally wired on the clutch pedal. If I recall correctly on the T10 there was a reverse light switch mounted on the DS of the transmission. Look for a harness around there.
Old Jul 6, 2016 | 12:52 PM
82' Z28's Avatar
You would be correct sir! Could you elaborate by what you mean by DS of the transmission? I don't suppose you meant down side?
Old Jul 6, 2016 | 01:09 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Luke, Turn To The DS . . . .
DS = Diver’s Side.
Better known as the left side.
Happy Racing !
8 Cylinders, No Waiting
Old Jul 6, 2016 | 01:57 PM
jkris53406's Avatar
Driver's Side is correct.
Old Jul 6, 2016 | 02:03 PM
82' Z28's Avatar
I am a goof, thank you both.
hiller1162
Interior Parts Wanted
Jul 6, 2016 03:57 PM
mdtoren
Jun 30, 2016 03:44 PM
CALIROCZ28
May 4, 2016 01:02 AM
Dyno Don
Apr 18, 2016 06:45 PM
Mattkovitch
Apr 9, 2016 06:46 AM
