Still no Spark 86 305 4bbl
Old Jul 21, 2016 | 06:58 AM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
ok, i changed the coil, the electronic ignition module (the old one tested good) and the condenser. still no spark. the only thing that i haven't changed is the pickup coil which i will do soon. i'm getting really sick of this thing sitting in my driveway not running.... is there a step by step tutorial for troubleshooting no spark in my bird? you know, check for 12v here if not do this if so..... that's really what i need because i hate no spark issues. if it has spark i can make it run but this stuff just makes me frustrated as hell...
Old Jul 21, 2016 | 09:31 AM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: Still no Spark 86 305 4bbl
I assume this is the big cap HEI? Check power to the distributor itself. The 12v power feeds the coil, pickup and module through that single wire. If there is power there you probably do have a bad pickup. Good luck!
Old Jul 21, 2016 | 03:18 PM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
thanks! ok, going out after the storms stop and will test those two leads going to the coil for 12v....
Old Jul 21, 2016 | 05:41 PM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
ok, i'm not getting voltage at the yellow/red wires that plug into the coil that's mounted on top of the distributer.... i checked my fuses long ago but then i just looked again at my chiltons and it says that there is a "courtesy" panel somewhere with what looks like more fuses.... where is it? THANKS!
Firebird2011
Jun 28, 2016 09:19 AM
Fonebooth
May 25, 2016 10:44 PM
zuhi
May 23, 2016 04:39 PM
2012sergen11
May 22, 2016 11:31 PM
thomashearts
May 5, 2016 08:40 PM
