Ignition Cylinder won't Turn Back?? Key stuck...
Car: 1987 Trans Am
I hope this is in the right section...
The 87 trans am I have been working on has an unusual issue (at least in my experience). The ignition lock cylinder will not turn back to remove the key
The car has been fine and I have been driving it around the yard, the issue just happened this morning. I can force the cylinder to turn back and pull the key but it isn't going back and locking as it has been and should do.
Any similar experience with this? I can see the rod move when I turn the key and look from underneath. The outer part of the column is a little loose and I can "wobble" it if that helps.
Transmission: Pro-built 700R4
Re: Ignition Cylinder won't Turn Back?? Key stuck...
You need to replace the ignition cylinder. I had a similar issue a few years ago. Not terribly difficult, just tedious and an pain in the butt.
Not sure how normal it is, but I know I had the issue and replacing the ignition cylinder fixed the problem.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Can also happen if the shifter isn't going completely into PARK.
Car: 1987 Trans Am
That's what I was originally thinking, I lifted the shift plate up and the shifter seems to be hitting the stop in the front when in PARK.
However I can pull the shifter back out of PATK without pushing the side button ...
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
It should lock in park.Most likely the cable at the trans is keeping it from going fully into PARK.Try adjusting from down there.
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Take the cable apart from the shifting linkage on the transmission. Make sure your transmission is in Park. Also make sure your shifter is in park. Now adjust the cable to the transmission linkage and put back together.
89irocz355
26
Sep 12, 2016 01:28 PM
