Excessive amp draw on my accessory fuse
Old Jul 21, 2016 | 08:12 PM
Red86SS's Avatar
Car: 1986 Camaro Z28
Engine: '80-'84 2 bolt 305, 58cc heads, FBO
Transmission: 1990 700R4 w/shift kit & 2-4 servo
Axle/Gears: 3.73 Posi (GT4 G80)
I am a new member and i just got my 1986 camaro z28 as a graduation present but my battery keeps dying because I have an amp draw from something on my accessory fuse but i cant find it. Any help is appreciated
Old Jul 21, 2016 | 08:40 PM
Re: Excessive amp draw on my accessory fuse
Pull the fuse and see what stops working.
Old Jul 21, 2016 | 08:57 PM
Red86SS's Avatar
When i pull the fuse the radio, horn and interior lights quit working and the draw goes away
Old Jul 21, 2016 | 11:16 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Is the clock on the radio always on?
Old Jul 21, 2016 | 11:36 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
That fuse also feeds the lighter. Anything plugged into that?
Old Jul 22, 2016 | 12:09 AM
Red86SS's Avatar
When the radio is on so is the clock on it and no there is nothing plugged into the lighter
Old Jul 22, 2016 | 04:58 AM
I'm going to assume you would have noticed if the lights were on all the time, so, probably nothing to do with those.
OK, so unplug the radio and put the fuse back in, and see if it stays away like that.
Also check for an amp; if it's wired to that ckt, then it's on 100% of the time.
Old Jul 22, 2016 | 07:09 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
most likely draw for an unmolested system is the cargo courtesy lamp in the rear hatch area. It can be left on and is dim enough to easily escape notice.
Old Jul 22, 2016 | 12:34 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
That light has been the source of dead batteries for me more than a few times.
Old Jul 22, 2016 | 12:38 PM
Red86SS's Avatar
I have checked the rear hatch light and it is always off. It could be the radio I'm thinking. I have a subwoofer with an amp attached in the back but its not wired to the accessory fuse
Old Jul 31, 2016 | 09:11 PM
Red86SS's Avatar
I fixed the problem. It turns out my radio wasn't wired correctly and there was a fuse missing that i didn't know about
Z28Bomber
Members Camaros
30
Mar 6, 2023 05:20 PM
RZOO
Apr 3, 2016 08:08 PM
87zz28
Apr 2, 2016 04:29 PM
SpencerG
Mar 29, 2016 01:24 PM
SRKLEGIN
Mar 27, 2016 05:57 PM
