Is this ALDL-OBD2 adapter safe to use?
Old Jul 28, 2016 | 06:02 AM
EnglishFirebird's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 v6
Transmission: Automatic
Hi all,
I bought this on ebay - an ALDL-OBD2 adapter cable for GM/Pontiac:
http://www.ebay.co.uk/itm/3018220182...%3AMEBIDX%3AIT
Before trying to plug it in and use it, I thought I would check the pinouts with a continuity checker...
I have attached a table of the pin connections as tested by me.
Can anyone take a look please, and say with any certainty whether this is likely to work?
I have a 1991 Base Firebird 3.1v6
Old Aug 2, 2016 | 09:51 AM
Engine: 3.1 v6
Re: Is this ALDL-OBD2 adapter safe to use?
Anyone?
Old Aug 2, 2016 | 11:17 AM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
What is your goal for use of such an adapter?
If you're wanting to then plug your ALDL car into a ODB2 reader, it would not do much for you.
Old Aug 2, 2016 | 12:09 PM
Engine: 3.1 v6
OK, my basic goal is to get as much information from my car as possible, ideally in real time while the engine is running, but also anything available in diagnostic modes etc.
I am sufficiently into electronics to make my own USB-serial interface chip based cable given time, and I'd be keen to make the ultimate diagnostic interface available as a product at some point, but for now I was after a quick solution, and found this ALDL-OBD2 adapter on ebay. I already have OBD2-USB and OBD2-bluetooth adapters so it would be nice if I could use these to connect the car to my computer and run software designed for our cars. The advert specified GM compatibility and it has the right plug/sockets. The pinout diagram I posted is from my own testing of this cable with a multimeter.
So my questions are - is it safe to plug in, and is it likely to be usable?
Old Aug 2, 2016 | 12:22 PM
thtanner's Avatar
No, you will not be able to use it that way.
GM ALDL is not compatible with ODB 2 adapters.
If you want to make your own ALDL to Serial adapter:
Otherwise you can buy premade USB cables here: http://www.1320electronics.com/products.html
and here: http://www.aldlcable.com/aldl.asp
Old Aug 26, 2016 | 05:08 PM
Engine: 3.1 v6
[QUOTE=thtanner;6065109]No, you will not be able to use it that way.
Hi, thanks, I have both those chips so will make up that adapter. I've seen some others I may try too.
Could you say exactly what the issue is with the cable I posted the pinout for please?
Cheers
Alex
Old Aug 26, 2016 | 05:14 PM
Engine: 3.1 v6
Cheers
Alex
Old Aug 15, 2017 | 01:13 PM
Pupkin's Avatar
Hi EnglishFirebird,
did you try to use your ALDL-OBD2 adapter with a standard OBD2 diagnostic interface?
Thanks.
Kind regards,
Pupkin.
the breeze
May 22, 2016 06:30 PM
Matthew1
Mar 18, 2016 02:40 PM
85maroz28
Aftermarket Product Review
Nov 21, 2001 05:03 PM
CraZyRob
Oct 31, 2001 07:05 PM
Get Blown ?
Sep 14, 2000 11:05 AM
