Hit a bump and the car dies for a moment - electronics help?
Old Aug 1, 2016 | 03:37 PM
777Shock777's Avatar
Engine: 5.7!
Hey everyone, this is on my 88 GTA.
My issue is while driving sometimes when hitting a dip, bump, rough road, etc. the RPMs will drop and the SES light will flash/turn on. - But literally within a second or two it will be back to normal as if nothing happened.
When I first bought the car it had a really rough idle - took it to a shop and they discovered a ground was incorrectly installed and the 'Computer' ground was loose. They fixed em, but the issue has come back so I want to check every single ground & maybe main electronics that could cause this.
Only electronics replaced are new battery & new starter, everything else is oem.
Any thoughts or grounds to check? thanks.
Old Aug 1, 2016 | 03:48 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: Hit a bump and the car dies for a moment - electronics help?
Do you see any dimming? Could check the fusible links by the starter. One of mine was blown but still making intermittent connection. Replaced all 3.
Old Aug 1, 2016 | 03:59 PM
Engine: 5.7!
You know, I do actually see a "pulsing" dimming on my dash lights & exterior lights. I'll have to inspect those wires when I get home.
But could that cause the entire car to act like I just turned the key to off? Then back on when it re-established connection?
Old Aug 1, 2016 | 04:10 PM
thtanner's Avatar
Sure can. They feed most the power to the car.
Old Aug 1, 2016 | 04:31 PM
Engine: 5.7!
Sweet, I really hope that's the issue.
I haven't messed with them before, does it require a specific gauge of wire?
Old Aug 1, 2016 | 09:02 PM
thtanner's Avatar
The fusible link is actually wire, pretty sure my TPI was 18 gauge (0.8 SQ mm)
Old Aug 1, 2016 | 09:42 PM
Finally Got one's Avatar
This SCREAMS loose ground or knock sensor
Old Aug 2, 2016 | 04:31 PM
Engine: 5.7!
Thanks I'll look into it!
Yeah I was really figuring it could be a loose ground.
Would it be a knock sensor going bad? or getting false readings? (car only has 82k miles and engine has no problems).
I'm thinking about adding another ground strap or two.
Old Aug 3, 2016 | 11:53 AM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
Definitely sounds like wiring. Have you tried shaking the wire harness and connectors while the car is parked and running?
Old Aug 3, 2016 | 07:14 PM
Engine: 5.7!
Good idea, I'll try that now!
Old Aug 3, 2016 | 11:02 PM
Engine: 5.7!
Thanks spurgeon76, I was instantly able to find the bad wire.
The previous owner wired the pass. side fan to come on if it hit a certain temp - come to find out they spliced into a wire that controls the fuel. (When you turn the key and this wire is bent/pushed you do not hear the fuel pump prime).
I also tried shaking the 3 fusible links while it was running and they seemed fine.
Going to do some re-wiring and I'll post back with my results!
Old Aug 4, 2016 | 12:38 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Any luck?
Old Aug 5, 2016 | 05:49 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Glad to hear you found it. I hate chasing Electrical Gremlins. I had a similar issue that turned out to be a loose connector on the Ignition Coil. I would hit a bump and the motor would shut off.
Bowtieman1970
Aug 17, 2016 02:50 AM
tonys91rs
Mar 27, 2016 06:04 AM
tognabologna87
Mar 24, 2016 04:41 AM
cannibaljeri
Mar 20, 2016 02:26 PM
MattW
Aftermarket Product Review
Jun 3, 2001 10:52 PM
