no juice getting to coil
Old Aug 2, 2016 | 07:26 AM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
i'm not getting 12v to the two wires going to the coil. i checked all my fuses. in the repair manual it says that there is a "courtesy panel" which i THINK has more fuses. where is it? any other suggestions would be greatly appreciated.
Old Aug 15, 2016 | 04:37 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fuse Ruse
Use a voltmeter to probe the primary of the coil when the key is in the RUN position.
Is there power?
If no, there is a bad or burned out connection between it and the ignition switch, or power to the switch.
There is no fuse in the suspect circuit however you should know where the fuse block is for future problems.
The Fuse Block is located up and to the left of the brake pedal, behind a small door.
Happy Racing !
Whether The Street Car At A Traffic Light Or The Nitro Funny At The Strip, Yellow Means Floor It !
Old Aug 15, 2016 | 05:07 PM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
Re: Fuse Ruse
by the "primary" you mean the part that rests on the rotor right?
thanks,
tim
Old Aug 22, 2016 | 04:13 PM
NINÅ's Avatar
Transmission: 765R4
Fuse Ruse
No, the primary is one of the wires coming out of the coil (usually red) and goes into the area that is terminated on the other side with a connector.
Happy Racing !
mcgarnicle
Exterior Parts for Sale
Jun 18, 2016 02:27 PM
The Chad
Jun 6, 2016 06:52 PM
Boosted357
May 28, 2016 10:02 AM
NiG
May 25, 2016 04:48 AM
mcgarnicle
May 20, 2016 05:10 AM
