Code 36
Old Aug 4, 2016 | 06:45 PM
shrewdpeach1609's Avatar
Code 36
I have an 88 Camaro, 305 TPI. About 1/3 of the times I try to start the car it stutters and I have to give it gas, otherwise it dies. Even then there isn't a guarantee that it will continue to run. It gives an error code 36 regardless if it dies or not. Occasionally I will have low throttle response, or it bogs if it gets throttle. I've replaced the MAF twice, and all three of the relays by the firewall. (Burning, power, and I believe fuel pump). I adjusted the timing, it was at -1 degrees instead of 6. That still didn't fix the problem. The dist. Cap and rotor are replaced, as well as spark plugs and wires. Any idea what is causing the problem?
broke91firebird
Sep 2, 2019 10:02 AM
M3638
Apr 5, 2016 07:57 AM
91banditt2
Mar 23, 2016 12:11 PM
db057
Mar 14, 2016 08:53 PM
theformula
Aftermarket Product Review
Dec 1, 2000 08:03 PM
