Keep blowing fuse
Old Aug 7, 2016 | 01:19 PM
ehale's Avatar
Keep blowing fuse
85 iroc with Lt1 swap
I keep blowing the 10 amp fuse labeled gauges. The wiring diagram I have shows the only thing on that fuse is gauges and cruise, I have removed all cruise components and the cluster is not in the car so the way I see it there shouldn't be anything connected but I'm still blowing the fuse. Suggestions please
Old Aug 7, 2016 | 01:33 PM
Re: Keep blowing fuse
I can't be sure, since your wiring diagram is turned the wrong way on my monitor, making it hard to read; but most FI setups use the "gauges" circuit for various ECM-driven things under the hood. Pink/blk wires are fed from that fuse.
That said, in a swap, it's impossible to guess what all might have been done wrong. Go back and check your work.
Old Aug 8, 2016 | 06:43 PM
ehale's Avatar
The problem was, I hooked a black and dark purple stripe wire to ground that came from the gauge power feed, In my defense it looked black when I did it.
Old Aug 9, 2016 | 01:04 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Purple is not a great tracer color for a black wire.
L0tuS
Mar 30, 2016 03:21 PM
neely8
Mar 27, 2016 01:17 PM
liva687
Mar 16, 2016 09:00 AM
ZDADDY92
Aftermarket Product Review
Dec 12, 2000 12:17 PM
Dan87IROC-Z
Dec 11, 2000 10:54 PM
