When I try to start my 1986 Trans Am
Re: When I try to start my 1986 Trans Am
Ok , so looking in there , IS there an engine ? If yes , and since we know there is a battery because things do light up and click , next up would be to get a set of jumper cables & a running car and give it a proper jump . Does it start ? If yes the two most likely suspects are the battery or the alternator , just don't forget there are several lesser seen causes as well that could cause it to need a jump so don't just run out and replace either the battery nor the alternator till proper troubleshooting tests actually prove one or the other to be defective .
PS , Welcome to TGO
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
Clicking noise is starter so look there first...test the voltage on the purple wire going to s terminal on starter .... battery voltage would help to know too
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Have you even checked the batt voltage? It may need a deep charge.A very discharged or dead will need more than a jump start.
