No tail lights, dash lights, headlights or dome light.
Old Aug 24, 2016 | 09:29 PM
Dracula's Avatar
Hello everyone, i was recently driving home and it started to get dark so i turned my headlight switch on but it didn't do anything.
Neither the head or tail lights work but the brake lights, signals and hazards do. High beams didn't work either and upon turning the switch on it didn't even show that anything should be lit up. The cel and stuff like that work tho.
The only thing i could think of is i had put tires in my back seat and a jack in the trunk, could it have messed something up?(it seemed to have cracked the plastic part in the back that hides the trunk latch etc...
I had heard something about the connections being made to the trunk, the part that's on was tilted forward a bit, could that have caused my lights to not work if it wasn't making connection?
Also a green wire is loose and the third brake light connector(black/orange and 2 red/white wires) was disconnected. Could any of these be factors? Or is it just my light switch is shot.
To add to recent events to see if anything could have caused it i did drop the tranny pan the other day and one of the bolts broke when i was driving home when the car shifted(shift kit and it shifts hard) could it have made the things connected to the starter that interfere with lights(cant remember the name) break?
thanks for any help.
Old Sep 6, 2016 | 04:20 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Dracula, You Can Count On Him
Your last paragraph was right on.
You might have broken a Fusible Link which is connected to the solenoid.
On most VINS there will be 3 Links there.
Happy Racing !
The Steering Turns Real Easy When The Car Is On The Roof
MantyZ28
Jul 24, 2018 07:47 AM
MantyZ28
Exterior Parts for Sale
19
May 6, 2016 11:57 PM
89irocz355
Apr 4, 2016 12:05 PM
89irocz355
Mar 27, 2016 09:52 AM
JakeJr
Aftermarket Product Review
16
Dec 3, 2000 01:17 PM
