Alternator
Old Oct 3, 2016 | 08:21 PM
Sutliff01's Avatar
Car: 1986 Trans Am
Alternator
I went and got my alternator tested today and it is no good so could that be the reason it doesn't do anything when you turn the key
Old Oct 4, 2016 | 01:15 PM
dlinger's Avatar
Car: 1984 Z28 HO
Re: Alternator
Good possibility. Alternator keeps the car running and charges battery. If it does not work, the engine will still run by using battery reserve. Once it is gone, car will not start or run.
You can check voltage with a mutli-meter. With car running voltage at battery with a working alternator should be 14-15 volts. Voltage without car running and a charged battery should be 12 volts.
Old Oct 7, 2016 | 12:01 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Alternator
Bad batteries or batteries at the end of their life put a strain on the alternator. Alternator is meant to provide power while the engine is running and only providing a slight charge to the battery to replenish it from starting the engine. Low charge or dead batteries make the alternator work harder because it senses a lower voltage in the system. When your alternator is bad your'e best to replace the battery at the same time (unless it pretty new). Replace or fully charge your battery (trickle charge over night) and then have the alternator tested.
Old Oct 10, 2016 | 04:57 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Answers Without A Question
What doesn’t do anything?
No solenoid click?
If your battery is good it will start the engine even if the alternator is bad or removed from the car.
Happy Racing !
“Professional Maniac Here, Do Not Drive 330 MPH In Your Own Home”
edpontiac91
Oct 31, 2016 07:17 PM
Billgluckman
Oct 23, 2016 09:38 AM
92firebirdchris
Exterior Parts for Sale
Oct 16, 2016 06:55 AM
jorgeblancojr
Oct 2, 2016 03:17 PM
edpontiac91
Sep 30, 2016 06:43 PM
