88 GTA wipers moving up and down 2 inches, only on High.
Old Oct 30, 2016 | 01:46 AM
777Shock777's Avatar
Engine: 5.7!
Hey everyone, I've read a few different threads on here concerning the same problem but I need some help.
When turning the wipers from Off to On-Delay you can hear a click by the wiper motor, but nothing happens on Delay or Low.
When you put it on High, the wipers go up and down about 2 inches back and forth non-stop, very rarely it will "catch" and go the whole span of the windshield.
I can buy a new cover and give it a try, but nothing appeared to be broken... the 3 prongs looked good as well...
Anyways, I took these two pics too.
Old Oct 31, 2016 | 09:34 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: 88 GTA wipers moving up and down 2 inches, only on High.
Are you aligning the blk wheel properly whe reinstalling the cover?
Have you tried replacing the park switch?
Old Nov 1, 2016 | 02:21 AM
Engine: 5.7!
Is there a specific way the black wheel is supposed to go?
No, I haven't had a chance to test anything yet - Where is the park switch located? I got another motor/cover on ebay for relatively cheap coming here this week so I will test it with that as well.
Old Nov 1, 2016 | 02:54 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yes, there's an arrow on it that points where it should face.The edge should just above the pin on that big gear.
The park switch is that white plastic with the three terminals, it's held by that bolt.
Old Nov 3, 2016 | 08:51 AM
RunawayRadio's Avatar
Car: 1987 GTA, Digital Dash
Engine: L98 TPI
Transmission: 1994 LT1 T56
Axle/Gears: 9 bolt, 3.27
^ What they said.
Old Nov 9, 2016 | 08:43 PM
Engine: 5.7!
I got a whole new motor/cover from ebay and just replaced the whole thing.
After inspecting it a bit, it looks like it may have been loose...
Regardless, its working again. Thanks for the help everyone!
