1986 IROC Gas Gauge Reads Over Full
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Ok, my poor old IROC has developed the dreaded Gas gauge/sending unit, reading over full problem. I bought this car about two years ago and have replaced almost everything on it, interior, engine/transmission, exhaust and brakes. I'm planning on regearing the rear end next, but now this gas gauge issue has reared it's ugly head and I want to fix it first.
I've already checked the gauge to make sure it's not sticking on anything and checked the ohms from the tank. I'm getting an infinite ohms reading indicating a break in the circuit. Last time I encountered this problem on a GM it was a bad sending unit, I think my plan on fixing it at this time is to buy a new sending unit and replace it; I want it fixed right the first time and not have to worry about it down the road.
Car: 1998 Viper/1996 Bronco
Engine: 8.0/7.3
Transmission: T56/ZF5
Re: 1986 IROC Gas Gauge Reads Over Full
If you replace the fuel sending unit (which I'm guessing may be the problem as well), I'd consider replacing the fuel pump at the same time with a GOOD pump like one purchased from GM or some other well known reputable brand.
It's a pain to get these tanks down, and if your pump hasn't been replaced, its only a matter of time before it goes out. I had to take off my exhaust and axle to get my tank down to replace my pump, and I don't look forward to doing it again (I may to put a higher power pump in now that I'm going to be upgrading to a 350.)
Edit: I just noticed your info says you have a carburated car.... so yeah you don't have to worry about the electronic fuel pump problem.
You still have to take the tank down for that sending unit though...
Car: 1986 IROC Z28
I have the same problem however mine started with the addition of an aftermarket fuel gauge. I haven't done any circuit testing however I'll be dam*ed if I'm going to drop the tank. Last time I did that I had to cut the exhaust off and I'm not ready to do that again until I have a new system ready to install.
I hoping that I can rework the circuitry and satisfy whatever sort of voltage the gauge needs to operate correctly. I'd rather pull the dash apart than drop the tank.
Keep us posted with what you find.
Car: 1986 IROC Z28
In my quest for horse power, I installed long tube headers and dumped the exhaust just before the rear axle, so thankfully I won't be dealing with the exhaust.
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
I'd put money on it your issue is with the sender, in all the third gens I've seen with fuel gauge issues 90% of the time it's been the sender. Unfortunately a good one is $120 or more.
Car: 1986 IROC Z28
Car: 1986 IROC Z28
I got lucky guys, found a dirty connector where the tank harness connects to the body harness. Cleaned, reconnected and it works like new again. I put the new sending unit on the shelf in my shop, I figure as long as I have a new one in my shop I'll never have a sending unit problem.
