blaster 2 coil, need ballast resistor or not?
Old Dec 29, 2001 | 09:37 AM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
I have reason to believe my coil is bad, at least I hope that's the problem. Most of the time the car barely has enough power to move itself and most of the symptoms seem to point towards the coil. Anyway I want to redo my ignition system and I wanted to be sure to get the right part. Do I need a ballast resistor with an MSD blaster2 coil for an 89 firebird 2.8 EFI. I'll probably get an MSD 6A along with it. I don't think I need the resistor but I'd like to be sure.
Old Dec 29, 2001 | 10:22 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If you use the coil with a 6A or 6AL, you will not nees the resistor. When connecting it to your stock ignition module, I don't believe you would need one, because there is no provision for bypassing the resistor while cranking the engine, but you would have to contact the MSD tech dept to be sure.
Old Dec 31, 2001 | 10:48 AM
MSD tech's Avatar
You do not need any resistors in this case. The only time you will a resistor is if the factory system requires one.
Thanks,
Joe
MSD tech
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
