Replacement rear defrost wire
Old Dec 18, 2016 | 02:59 PM
1987L69's Avatar
Car: 1984 Z28
Engine: LG4 305/4bbl for now
Transmission: 5-Speed
Axle/Gears: 3.23 Posi
So the wire that connects to the heating element on the back glass is broken from opening and closing over the years and was wondering where to find a new one at?
Old Dec 18, 2016 | 05:07 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: Replacement rear defrost wire
I'd like to know as well. Mine is just frayed wires now. The plastic sheathing is gone.
Old Dec 18, 2016 | 06:46 PM
I have used #10 Hypalon insulated motor lead wire. Real flexible.
Gotta be careful about the orientation you install it in; as mentioned, the act of moving the glass wears it out. If memory serves, I used a 90° terminal on the end to hook it to the lift cylinder.
Corrosion is the enemy.
