Ignition switch
Old Dec 23, 2016 | 03:12 PM
Slayze's Avatar
Car: 87 Trans Am
Engine: 355 Carb. Nitrous 100 shot
Transmission: TCI Performance Trans. 350 Turbo
Axle/Gears: Borg & Warner 9 bolt 3.70 gears
Ignition switch
I noticed my switch that the ignition rod goes into on the steering column was hanging loose. After I crawled my old *** under there to reattach it I noticed the rod was moving freely by hand. So I take the steering wheel off/apart to see if it just need reconnected, but I see nothing for the rod to connect to so it moves with the key. I don't know if you can buy whatever is missing so what I am looking at doing is putting a starter button on it and only using the ignition to unlock/lock the steering wheel. Has anyone completely eliminated that rod and switch? If so what's involved? The switch itself has a yellow wire (I'm thinking it's the starter switch?) Brown wire ( I'm thinking is accessory?) And 2 green wires (I have no clue what those are for?). To do this I'm thinking the accessory would have to be put on a switch as well. Don't know if it matters but I don't have a computer anymore I took it out when I took the motor out and put a carbed motor in. From left to right brown wire, yellow wire, green and green.
This is the rod that I see nothing to connect it to.
Old Dec 23, 2016 | 03:37 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: Ignition switch
That's not the ignition actuator rod, that's the high beam rod.
Old Dec 23, 2016 | 04:02 PM
Slayze's Avatar
Car: 87 Trans Am
Re: Ignition switch
Well that just made things easier 😋 thanks I appreciate the reply. Have a good Christmas.
Old Dec 23, 2016 | 05:31 PM
Re: Ignition switch
Right: and what's in your hand is the headlight wiring.
One wire is the feed from the headlight switch (headlights: yes/no) and the other 2 are high and low beams respectively. Black of course is ground.
Old Dec 23, 2016 | 07:57 PM
Drew's Avatar
Re: Ignition switch
It's fairly common for the high beam rod to fall out of the switch. There's a cup on the switch for the end of the rod.
Old Dec 26, 2016 | 08:29 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Ignition switch
Excellent reference photo, Drew. I'll be saving a copy of that one.
