88 camaro cruise control
Old Feb 12, 2017 | 12:11 PM
Jayson Davis's Avatar
Just installed a new blinker switch after previous owner broke it. It has factory cruise but for the life of me can't figure out or find where the cruise control plug hooks up under the dash. Any help to finding this mysterious plug would be much appreciated
Old Feb 12, 2017 | 02:50 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: 88 camaro cruise control
The cruise control connector (C235) coming from the lever should be square, 4-wire with blue, green, red and yellow wires.
I don't think this changed from 1987 to 1988.
Old Feb 12, 2017 | 03:54 PM
I got this lever ​​​​​​​http://www.stylintrucks.com/parts/replacement_turn_signal_switch/reptu38855/replacementarbc505402-.aspx?scid=gglpla&gclid=CjwKEAiArIDFBRCe_9DJi6Or0UcSJAAK1nFv7XESuOWS5RDheguYxPQDKWc9cdZsU5ONqYlIoEHLIxoC2Wbw_wcB# its not a 4 plug but a single plug.
Old Feb 12, 2017 | 08:41 PM
Drew's Avatar
It's one plug with 4 wires. The tab on the end of your switch has 4 terminals, when it's plugged in the terminals press against the terminal for the 4 wires.
They don't look like they'd match up, just look for a square plug with 4 wires.
Old Feb 13, 2017 | 07:27 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Find the brake light switch. C235 is part of this harness.
