fuel pump wiring question
Car: 1985 trans am/ 1991 RS
Engine: 355sbc/ v6
Transmission: 700r4 automatic
Hey guys, I have a 1985 trans am, the car has a carb atm, i am installing a holley sniper efi to the car, i have already installed the electric fuel pump in the tank and see there are three wires going from the connector i have found out with the help on this forum that the pink one goes to gauge the black is ground, but the tan wire is power, now being that the car was originally a carbed, where does this tan wire go, i want to tap into it for the fuel pump relay, i have traced it all the way to under the dash, it seems to connect to another connector with a lot of other wires, but from there i can seem to figure it out,
would it be possibly entering into engine compartment?
thanks
thanks
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: fuel pump wiring question
I am working on an '85 TA right now, that wire stops at the 15pin connector (c207)
I am doing FI also.
I am doing FI also.
Engine: 355sbc/ v6
i believe c207 connector is located on passenger side?
what FI setup are you going with?
Engine: 355sbc/ v6
this is great, ill take a look tmrw morning, gosh i just put the interior all back together now im taking it all apart again for this Fuel injection
