Temp Gauge Inaccurate
Old Mar 10, 2017 | 06:34 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Ever since I did my headers and exhaust, the temp gauge has read about 50 degrees low. It seemed to work fine before then
The fan comes on when it should, at 193 degrees, but I went ahead and changed the sending unit, anyway. No help.
Does anyone have any ideas?
Old Mar 13, 2017 | 05:02 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Temper Tantrum
Here’s how to test the temp gage.
Disconnect the
green wire from the temp sensor.
Clip in a 100 ohm resistor from that wire to the
battery terminal.
Turn the key to RUN.
If the gage is good it will read about 220°.
Happy Racing !
I Smacked The Wall With The Side Of The Car Because A Narrower Car Is A Faster Car
Old Mar 14, 2017 | 09:56 AM
Engine: L03 305 TBI
Re: Temper Tantrum
Disconnect the
battery terminal.
Happy Racing !
That's good information, thanks for your help.
I remember reading something about a pigtail causing a similar problem a couple of years ago, but I can't find the thread.
