Speed density wiring issue (solved)
Old Mar 13, 2017 | 12:55 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I am going to throw this out there in case anyone else has had the problem.
I am working on a '91 SD harness. (730 ECM)
The problem..... the ECM does not turn on the primary fan.
The temp control is set at 190* even at 220* the fan does not turn on.
I ground the wire at the "E" 8 terminal on the ECM connector and the fan comes on but the ECM won't turn it on. (so the relay is good)
I have checked all the grounds at the ECM connectors that connect at the back of the heads and they are all good.
Also, the 02 sensor reading is not right and when I open the throttle the engine pops and bangs. It runs ok at idle and 3000 rpms
I must be missing something somewhere.
Any help?
Old Mar 13, 2017 | 01:02 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Speed density wiring issue
For the fan issue is the programming set to no or nc ?
sounds like you have a bad ecm.
Old Mar 13, 2017 | 01:10 PM
Dyno Don's Avatar
Normally open
I have tried several known good ecm's, no change
Old Mar 13, 2017 | 02:13 PM
Engine: Lb9
Transmission: M20
Is e15 ground good ?
Old Mar 14, 2017 | 04:15 PM
Dyno Don's Avatar
Re: Speed density wiring issue (solved)
Yes, it was good. (E 15)
N.O. fan fixed that fan issue
The pickup coil in the dizzy was bad
Old Mar 14, 2017 | 04:16 PM
Engine: Lb9
Transmission: M20
Good find
