High beams
Re: High beams
Sounds like the switch needs adjustment.
Loosen 2 screws that hold it onto the column; slide up and/or down until it works right; tighten screws.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: High beams
and if your tilt column is loose, tighten it and you may not have to re-align your high beam switch
