1992 convertible TA 3rd brake light bulb
Old Mar 31, 2017 | 11:10 AM
obomb3277's Avatar
Car: 1992 Trans am convertible
Transmission: standard 5 speed
Who can identify this bulb for me. I have looked at multiple threads but none seem to be correct. This bulb is from a 1992 trans am third break light. The biggest callout I could see is it has a tail of sorts between the 2 prongs that fits into the light socket. Pictures attached. I need to replace these but have no clue where to get them or what they are. Thanks for the help.
Attached Thumbnails 1992 convertible TA 3rd brake light bulb-20170331_120442.jpg   1992 convertible TA 3rd brake light bulb-20170331_120024.jpg
Old Mar 31, 2017 | 12:23 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: 1992 convertible TA 3rd brake light bulb
http://www.top-downsolutions.com/Bod...b-clear-10watt
Old Mar 31, 2017 | 01:09 PM
obomb3277's Avatar
Originally Posted by blacksunshine'91
The bulb looks different though, does it matter if it has the middle glass tail that fits into the bulb socket?
Old Mar 31, 2017 | 04:11 PM
That is the bulb you need. If you are unsure, you can call Lon and talk to him. Those are the exact bulbs that I ordered and are working just fine in my '92 TA convertible.
Old Apr 2, 2017 | 08:16 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
They're #891 bulbs.
You should be able to get replacements at Home Depot in the outdoor lighting aisle. You can use either the 10 or 20 watt versions.
