ignition switch
Old Apr 1, 2017 | 09:58 AM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
ignition switch
ok, i've bought two ignition switches and both were wrong for my car. i have an 86, TA, WS6, 5sp, tilt wheel, 4bbl. the switches that i bought have the actuator rod mount on the side. my rod plugs into the switch from the bottom. can anyone tell me the correct switch for my application?
thanks!
Old Apr 1, 2017 | 11:04 AM
Vader's Avatar
Re: ignition switch
Can you read the original (Delco) part number on the switch plate? It could be 01990116 or something similar. That should be a clue as to the appropriate replacement.
Old Apr 1, 2017 | 11:15 AM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
Re: ignition switch
well, i took it apart to see what's inside and then threw it away. i had no idea that i'd have such a hard time finding the right one.
Old Apr 2, 2017 | 08:00 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: ignition switch
It might be of some help to look at some of the switch photos here:
http://www.rockauto.com/en/catalog/p...er+switch,4700
Keep in mind that some photos might be stock images and may not depict the actual part.
Old Apr 2, 2017 | 08:15 PM
George Klass's Avatar
Car: 1989 Trans Am
Re: ignition switch
When you dropped the column was the switch mounted to left or right side?
D1405B AC Delco left side
D1404B AC Delco right side
Old Apr 2, 2017 | 09:33 PM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
Re: ignition switch
THANKS!
Old Apr 2, 2017 | 09:35 PM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
Re: ignition switch
the screws were on the left side of the column and also held the brights switch but the ignition switch itself was on the very top.
Old Apr 2, 2017 | 09:37 PM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
Re: ignition switch
you see how this switch has the actuating rod going into the left side. my rod points straight up and must mount from the bottom unless i'm missing something.
