who sells the best power window motors?
Old Apr 20, 2017 | 11:48 AM
JimRockford's Avatar
The power windows on my car have gotten very slow and the passenger side takes forever to go up and down.
I was looking online and you can buy a set of power window motors on eBay for $49.99 for the pair with free shipping. Are all the replacement motors for these cars the same or is there a certain brand that last longer and works better?
Old Apr 20, 2017 | 07:43 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: who sells the best power window motors?
How slow is slow? These things aren't exactly or even remotely fast normally. Could just be your window tracks are dirty or gunked up or the motors need lubed. Do a search for power window maintenance or lubing.
Lots easier to try first
Read some threads about replacing the motors first also
Old Apr 21, 2017 | 01:54 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I avoid anything that comes in a Cardone box (numerous leaky PS pumps out of the box; same p/n). Unfortunately, we're at the mercy of availability with old vehicles.
I had to replace a dead window motor in my Acura with a Cardone rebuilt unit. It's minimally better than the dead motor. It's so slow you can plant and harvest corn before the window shuts.
Old Apr 21, 2017 | 04:44 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
https://www.thirdgen.org/forums/inte...relay-kit.html
check out this thread,his kit made my windows go twice as fast.GM has the best motors,if you don't want to go that route,1A sells a decent motor.
Old Apr 21, 2017 | 06:13 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
If you go the route of the relay(s) you can make them yourself with the parts from partsdirect.com. That particular classified ad popped up in 2014, I made my thread in 2013 (https://www.thirdgen.org/forums/elec...-switches.html) that talks about doing the same thing and there are members that chimed in that had had it done before me and helped me out. Really is pretty easy and cheap to do.
If you are looking to get every last bit of life out of the motor you can read this thread:
https://www.thirdgen.org/forums/inte...ows-power.html
That along with cleaning the tracks may extend the life a little longer but bottom line is that window motor is at least 25 years old now....
I used a new motor from AutoZone and it has been fine.
Old Apr 21, 2017 | 08:05 PM
Drew's Avatar
If a person is going inside the door, I'd absolutely recommend cleaning and lubing the window tracks. My latest project car, the old grease was hard as a rock and full of dirt. In plenty of places I had to chip away the stuff since it was more like concrete than a lubricant.
I wouldn't expect it to fix a bad motor, but it's regular maintenance most people never perform.
