Headlights not working
Old Apr 21, 2017 | 06:09 PM
Slayze's Avatar
Car: 87 Trans Am
Engine: 355 Carb. Nitrous 100 shot
Transmission: TCI Performance Trans. 350 Turbo
Axle/Gears: Borg & Warner 9 bolt 3.70 gears
Ok I did some searching but I can't seem to find it. I think I screwed up. I got rid of my high beam switch since it didn't need it and tossed it. Do I need that connection for my headlights to come on? They flip up but no lights. If the switch was needed to power the lights what color wires would I need to splice together to bypass the switch for power?
Old Apr 21, 2017 | 08:00 PM
Drew's Avatar
Re: Headlights not working
So you started deleting stuff without knowing how it works?
Yeah, you need the hi/lo beam switch. You could splice two of the wires together, or make a jumper wire, but I'm gonna let you find a wiring diagram yourself, because you should have looked it up before just tossing a piece you might need.
Old Apr 21, 2017 | 08:06 PM
Slayze's Avatar
Car: 87 Trans Am
I figured it out. Thanks
