Wont turn over
Old Apr 23, 2017 | 10:28 AM
stegal's Avatar
Car: 1990 RS, 2002 Chev Silverado
Wont turn over
I have replaced the ignition switch and ignition key and still will not turn over. Just died about a week ago. Have power to everything and can hear fuel pump.
Any help is great.
Old Apr 23, 2017 | 10:31 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Wont turn over
Have you tried to bypass the key cylinder resister.
http://www.austinthirdgen.org/index.php?pid=41
Or check power at the starter enable relay?
Old Apr 23, 2017 | 11:17 AM
stegal's Avatar
Re: Wont turn over
The new key I put in doesn't have the resistor. Where is the relay for the starter? Thanks Steve
Old Apr 23, 2017 | 12:24 PM
Engine: Lb9
Transmission: M20
Re: Wont turn over
The starter enable relay is under the drivers side kick panel. Jumper the larger gauge wires yellow and green.
