bad static thru speakers with radio off
Old Apr 28, 2017 | 05:51 AM
ezstriper's Avatar
Car: 91 Z28
Engine: 6.0 LSX 88 Turbo, EFI E85
Transmission: Glide
Axle/Gears: Strange 3:73 9"
weird issue, while driving getting bad static thru speakers even with radio off, figuring a ground issue, anybody ever heard of this one ? 92 Z28
Old Apr 28, 2017 | 08:27 AM
brettr81's Avatar
Car: 91 Firebird
Re: bad static thru speakers with radio off
Do you have an amp?
Old Apr 28, 2017 | 10:13 AM
Griffin92rs's Avatar
Car: 1992 camaro rs
Engine: 3.1 v6
I'm having the same problem but mine stops when I turn off the radio. worse since i put in the new amp.
Old Apr 28, 2017 | 11:58 AM
brettr81's Avatar
Car: 91 Firebird
It's probably a bad ground, add in some ground wires. Also, if you ran the coaxial and power near each other, that can cause it as well. Cheap coaxials will do it too.
Old Apr 29, 2017 | 06:48 AM
ezstriper's Avatar
Car: 91 Z28
Transmission: Glide
nothing been added car 100% stock, I loosened moved and tightened the ground off the battery and the one on the firewall and took out about 90% but still some there
Old May 1, 2017 | 10:02 AM
Car: 1992 camaro rs
Engine: 3.1 v6
where exactly is that ground on the firewall?
Old May 1, 2017 | 12:20 PM
ezstriper's Avatar
Car: 91 Z28
Transmission: Glide
comes from passenger side head to firewall, ground strap
