turn signal switch on 1991 camaro
Old May 4, 2017 | 10:14 PM
billyjoe's Avatar
would my turn signal switch be bad if everything works except it wont switch to high beams,any help would be greatly appreciated
Old May 5, 2017 | 12:15 AM
Drew's Avatar
Re: turn signal switch on 1991 camaro
No, high/low is controlled by it's own switch further down the column under the dash, next to the ignition switch.
The high/low switch probably isn't bad either. What usually happens is the tilt pivot pins back out, the column gets sloppy loose and the rod that runs from the multifunction switch (turn signal stalk) falls out of it's pocket on the switch, or it just cant travel enough to activate the switch.
Old May 5, 2017 | 06:38 AM
billyjoe's Avatar
thanks drew i greatly appreciate your help
robguitargod1
Mar 25, 2019 05:50 PM
Falconiroc
Members Camaros
24
Aug 4, 2017 04:37 PM
navy02ws6
Mar 1, 2017 06:47 PM
GMan 3MT
Feb 23, 2017 11:58 AM
Michael Canfora
Exterior Parts for Sale
Feb 22, 2017 05:50 PM
