Help Identifying Connector
Old May 11, 2017 | 08:31 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Hey guys I am working behind my radio and I found a connector that isn't plugged in to anything. All systems work fine, but I probed it and one wire was hot with key on. I may use this as a power source for my Wideband, but I'd to know what it is first. Any ideas? It's a Manual trans car, maybe a connection for an auto that I just don't need?
Old May 11, 2017 | 09:04 PM
Re: Help Identifying Connector
Looks like you have a 5-spd car... that would go to an auto shifter.
Neutral safety sw (yellow & purple), backup lights (blue & green), a copy of the dash lights(org & blk).
Old May 11, 2017 | 09:44 PM
BronYrAur's Avatar
Engine: 305 TBI
Perfect, thank you. So, it looks like the blue wire for the backup lights is always hot with key on. Any idea if one of the other terminals could be used for ground? Otherwise I'll just ground it to the chassis.
Old May 12, 2017 | 05:53 AM
Depends on what "it" is that you're wanting to ground... for a VERY low-current, low-power application that isn't critical, and that can tolerate lots of noise and uncertainty, like a backlight bulb, you could use the black one. Anything more elaborate than that, I'd go to the chassis. Definitely wouldn't use that for a WB. Probably best to ground that to the block or similar. (casting)
Old May 12, 2017 | 07:02 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Ha ha just made this thread. I was thinking about using blue for a wide band as well but I ended up tapping into the fuse box and running it over with an inline fuse per AEMs instructions. I also used a chassis ground.
Old May 12, 2017 | 12:53 PM
BronYrAur's Avatar
Engine: 305 TBI
Thanks for the replies. This will be for wiring an Innovate LC-1 Wideband. So, I'd probably be best pulling a new/clean power/ground line. Maybe a relay that uses the blue to switch it on and a separate power line back to the fuse box.
