12v accessory power for my cluster
Old May 20, 2017 | 08:12 PM
89BlkIROC's Avatar
Car: 1989 IROC
Installing a new cluster in my 89 and I need a 12v accessory power. The kit says to use the fuse box, but I can't find any open areas that does accessory (used a light tester with the key in the ON position, no luck) anyone know of any wires I can piggy-back, or should my fuse box have an open slot?
Old May 23, 2017 | 06:18 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Dash 4 cash
There should be terminals in your fuse block labeled BAT.
You can connect a fuse it.
OR
They sell fuses with pigtails on them in which you can use that fuse.
Just make sure you select the correct side so if the fuse blows power will be cut.
Happy Racing !
Don’t Fuss Paintin’ Your Back Bumper, Cause B4 The Race Is Over I’m Gonna Be Pushing You Out Of The Way
Old May 24, 2017 | 03:46 PM
89BlkIROC's Avatar
Car: 1989 IROC
Re: Dash 4 cash
Pulled it off the ignition, thanks!
Old May 24, 2017 | 06:29 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: 12v accessory power for my cluster
The original cluster wiring has a switched power source. It is the PNK/BLK wire at the brown connector.
https://www.thirdgen.org/forums/ltx-...ml#post6111293
Old May 24, 2017 | 06:32 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Oops, sorry, I just noticed you have a Camaro not a Firebird. Nothing I said applies to you.
Although, the same concept must be true, you just have to find the wire.
