How do I remove the instrument cluster on 1990-1992
Old Jun 6, 2017 | 02:03 PM
steves's Avatar
Car: 1991 Camaro RS B4C
Engine: 5.7 TPI Crate Motor
Transmission: WC T5
Axle/Gears: 10 Bolt 3.42
How do I remove the instrument cluster on a 1990-1992 Camaro? I also need to remove the chip off the tach.
Old Jun 7, 2017 | 02:42 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: How do I remove the instrument cluster on 1990-1992
First you take off the hush panel? from underneath the steering wheel on the driver side. Big padded piece with I think 5 torx screws. You then have access to remove the gauge bezel. Few 10mm screws on the bottom and the top pops right off with a gentle tug after you remove either the headlight **** or **** and shaft. You'll need to disconnect the lighter as well. Unscrew the screws holding the cluster in and it comes right out. Easier if you tilt the wheel down as far as you can and carefully snake it out. Reverse for install. Not hard just takes some patience.
Old Jun 7, 2017 | 05:11 PM
steves's Avatar
Transmission: WC T5
Thanks for the help.
Old Jun 7, 2017 | 06:27 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Oh yeah, and after you tilt the wheel down it makes it easier to get the cluster out if you remove the tilt lever too. Good luck!
