CCC distributor advancing without ECM
Old Jun 16, 2017 | 01:01 AM
peppersteak's Avatar
'82 fb lg4:
CCC distributor advances from initial 9° BTDC at idle to 22° at 2500rpm (total).
The ECM is unplugged and also a Non-CCC carb installed.
How is this possible? Distributor doesn't have weights.
curve is something like:
9° @ 800 RPM
12@1200
15@1500
18@1800
20@2000
22@2500
i don't understand. the ccc distributor doesn't have any signal to advance the timing, it should do nothing. am i wrong?
Old Jun 16, 2017 | 06:58 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: CCC distributor advancing without ECM
built in limp-home advance in the ICM.
Old Jun 17, 2017 | 12:00 AM
learning something new every day. thanks!
Old Jun 17, 2017 | 01:09 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
If you dig into the Helms service manuals, they go into some detail, there's usually a low speed section, and a hi speed section. A Delco module usually has a better backup system than aftermarket.
Old Jul 7, 2017 | 08:19 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Alot of GM carbureted marine engines use the small HEI EST distributers running without any ECM input.
