1992 corvette tach reads "0", fuel gauge reads "0"
Old Jun 24, 2017 | 07:10 AM
jmk1938's Avatar
1992 Corvette c4 electronic ignition, tach reads "0", fuel gauge reads "0"; The charging system is intermittent since a voltmeter on the battery will read 12v, and sometimes 14.5v. The alt tested good, and the dash voltmeter reads when a voltage is applied to it. Where is the tach filter located and how can I test it? What is the wire path from the dash to the point the voltmeter gets its voltage?
Old Jun 26, 2017 | 05:04 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1992 corvette tach reads "0", fuel gauge reads "0"
Iirc the inputting for the cluster is feed bye the bcm. You will have better diagnostic at corvette forum.
