Dash Light Connection
Old Jul 1, 2017 | 10:08 PM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
does anyone know of an easy location to tap the dash lights? I am adding a boost gauge and want to tie in and dim it with the dash lights...
Old Jul 1, 2017 | 10:32 PM
allos's Avatar
Car: 89 GTA, 84 T/A
Engine: L98 stock, Carbed 350
Re: Dash Light Connection
The radio harness would probably be the easiest point.
http://www.iroczone.com/images/wiring/1992wiringb.gif
I believe it is the grey wire you want, I think the brown wire only controls the clock dimming.
Old Jul 2, 2017 | 07:14 AM
Drew's Avatar
The fuse block is easier still. There are extra terminals in the fuse block for gauge lighting, constant 12v+, and switched 12v+. If you want to get really fancy, you can buy the Delco connectors that plug right in, but most people just use a male spade terminal.
Old Jul 2, 2017 | 07:55 AM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
That's awesome!! I am coming right down there with a harness but wouldn't that be a full 12 volt source not dim with the dash lights?
Old Jul 2, 2017 | 09:45 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Drew is correct, look for an opening that is labeled either LPS or INST LPS. That is the dimming circuit.
RBob.
Old Jul 2, 2017 | 10:39 AM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
thanks guys, worked awesome!!
