Can anybody tell me which one does what (ON wire)
I'm trying to wire up a push button start, and eliminate the need for a key, I do have a hidden kill switch so the car wont start with it off, I'm tryin to find the ON wire so that when I flip the switch everything is ready like switching the key to the on position. For the questions on why, it had no keys, the ignition switch is bad, and simple enough I just want a push button start, always have lol
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Buttoning Up The Project
You didn’t sat the year and model so this info is generic.
Connect the ON▬OFF switch to the 12 AWG pink wire and the 10 AWG red wire presently going to the stock ignition switch VIA the steering column connectors.
Happy Racing !
He Must Have Been Cheating - Because I Was And He Almost Beat Me.
Happy Racing !
Re: Can anybody tell me which one does what (ON wire)
Its a 1989 iroc, with 305 carbed, ok the pink and red operate the ON, is the orange and red for the ACC, that has to be on as well right to a toggle???
Transmission: 765R4
The accessories will come on when you connect the wires as in post 2.
The yellow wire goes to the neutral switch.
The brown wire is the wire that passes power to the accessories.
It should be live when you connect the wires as in post 2.
Happy Racing !
Happy Racing !
